hi all does any one have a manual that they can send me on cd or ?? as i need to no wat the timing marks on on my 2.2 td estima M reg 4x4 i just brout i none runner its had new pump and engine but broke down on the person is starts but runs rough i think the pump timing is out can any one help me please thanks mark
i thought estima carries fixed pump so you cant adjust the pump but you can the timing more info needed
hmm i got it running now the recon pump had bin put togeather wrong if i line the timing marks up in the right place on the pump its knocks it head off, i moved the pump round abit and i got it to run, but alot of smoke, i decided to get a second hand pump and it worked fine with the marks in the right place, still smoked thow i found that the EGR valve was abit dodge i took the small pipe of it and smoke went PUFF away LOL all sorted it seems to run ok as it is now, do i need to sort the EGR valve out or can i leave the pipe of it ????????
thanks anyway mark
just block the pipe
