Low power at inclines
Ribopaido
Hey all,
I have a toyota iq 2019 1000cc manual transmission 4 months now . After having an issue with an ignition coil at 60k miles (or 100k km) which is fixed and car is working great except at inclines where it has limited power. Even though I press the throttle almost completely and car raves to 2k-2.5k RPM, then it starts dropping to 1k rpm and it starts normally but slowly. I know it needs new tires and clutch probably cos of the typical vibrations at 2k rpm (slight slipping at 4th-5th gear though)  but could it be a bad egr or catalytic converter issue? No active recalls found and car is checked with OBD tester but no error or engine light on.  I can check egr and postcat o2 sensor values with my own semi-pro obd tool but should I do anything- is it counted as a problem?
It looks like the EGR valve problem for which there was a recall
Presumably the OP has already checked for recalls.
Yes no active recalls, ill go get it cleaned tomorrow along with map sensor though to see if it gets better
Greece but the car was imported used from germany.
oh ok just found the TSB Number EG-0064T-0811 if that helps
Μy problem is at high inclined hills only though, bit weird isn't it? I thought egr issue was only at CVT gearboxes ones
