Hi,I'm have a problem with my ABS at very low to stopping speed,there are no dashlights on but the ABS "Kicks back" through the pedal ?
Any ideas ?  Regards,Stuart
Moved to the Corolla club.
Isn't that normal for ABS ? Assume you are keeping your foot pressed hard down all the time, as you should.
This has only started to happen in the last month,I'm talking about light braking,when you brake hard all is working as it should,especially with the EBD
