Hiace sliding door
Karlosvan
Hi All,
I have a 2008 SWB Toyota Hiace I'm looking to convert into a camper, the current sliding door has some damage and I'd like to replace it with a glazed version. A local breakers yard has a LWB version, looking online the dimensions are the same as the SWB door but the breakers says it will not fit, my local dealer can't tell me either, can anyone help?
Is it a jap import or a uk van ? Left or right door
can you pm me your Vin so i can pinpoint your exact model
It's a UK van I've pm you, thanks!
The campers/lwb van/bus are jap or general worldwide spec Hiace, the short wheelbase (SBV) is different - you need to find a uk spec one
Edit. There are 2 types with or without power door, the standard one is 67004-26410 - power door 67004-26400 (sub 67004-26380)
otherwise, go measure one
Thank you, I'll see if I can pick a SWB one up and fit the glass after 👍
