Horn relay where can I get them
Bob mayhew
Please can someone tell me where I can get a relay for my Toyota auris it is a 2012 model
A Dealer or breakers do you have power to the load and coil side of the relay ? The switch is on the ground side of the coil, I take you have tested the horn and checked the continuity of the clock spring
Edit. Its part of the Integration relay module
Which model Mk1 2006-2012 or Mk2 2012-2019, what's the issue ?
