On a less than smooth surface I use every day the passenger seat rattles irritatingly.
Is there a known fix for this, before i take it to bits?
If there's someone sitting in it, it's fine.
Does the seat wobble in locked posion
Sent from my G8341 using Tapatalk
Move the back of the seat one notch either way. Worked for me 😉
I’ve had the exact same issue from day one! And I for one agree it drives you potty !!! However if it’s just me alone in the car i pull it all the way forward,, rattles gone, it’s only when it’s pushed towards the rear to centre that it goes off on one. Try my pull forward position..might work for you too.
