Yaris hybrid 2012 not starting
Cribim
Hi All
New to this site. I got a yaris hybrid which was all OK till lock down. It started in April the car won't open when pressed the fob. Used the key to get in and tried pressing the ignition but no luck. After 10 min I tried again and it is OK. Went to the dealer and the Battery got changed again. All fine next day. But tried after 3 days same problem the door won't open. Tried today but no luck. Sat in the car for 5 minutes pressing the ignition and suddenly it started. Any idea. Tried using the spare key but it is the same.
Rgds
Cribim
Welcome to Toyota Owners Club.
Toyota issued advice back in April on Battery maintenance -
Moved to the Yaris club.
Keyless start ? If so change the Battery in the fob (use good quality cells)
Will it go into ready mode if you press the brake pedal down a few times, I take it you have it in Park ?
Does it go into accessory mode with one press of the start button ?
Have you tried placing the fob on the button until you hear the steering lock, unlock
