Cruise control for 1.0 engine
Seddik
I have 2019 Yaris 1.0 , with the new 1krfe (dual injector per cylinder)
the model mark of my yaris is R , in toyodiy the cruise control show me that is not applicable !
but the others model mark ( N and G) support cruise control and the part number exist
I bought cruise control from eBay and i installed it
116704731_651291178928310_1052727329374805706_n.thumb.jpg.b8e119e8388e3685c01898d9deb34dab.jpg
but he won't working
please help me if there is a solution
my ECU part number is 89661-0UB10
The 1.0 doesn't have the wiring and/or its not programmed into the ECU
have search on here there are a few thread on the subject
but how to know if the ECU support cruise control or not ?
Make sure it's all wired including the clutch switch then test, normally the 1.0 will be missing the wire from the multi plug (up under the dash) to the ecu
i will have a look but i don't think i have the diagram for a yaris this new
Clutch switch star and switch cruise control are installed
But what's the pin number on the ECU that manage the cruise control
117104320_290356852063963_3869566805003977821_n.thumb.jpg.ae8deb8c0e4d9fcda7fa8d4c6007df24.jpg
I found the problem 😥
The ACCELERATOR PEDAL does not support cruise control
I have the 78110-0D110 , not support
78110-0D120 support the cruise control
24 minutes ago, flash22 said:
pin 33
Sure ?
Do you have a diagram ?
Its connector A58, Pin 36  Pin 33 is the TC for the DLC
2017 onwards
2017 onwards
Sorry but what's TC for the DLC mean ?
And what's the difference between 35 an 36 pin ?
CCS and ECCS ?
If i found that pin is exist, then i shoud reprogram my ecu ? Thank you
The second pin is the ground related to that circuit so pin 35 is the ground for pin 36
DLC is Data Link Connector aka OBD2 - TC and GC is used for specific diagnostics
So when i connect the cruise control
I should using 35pin as a groud ? I should connect 2 wires to the ECU ?
16 hours ago, flash22 said:
Just check to see if 36 is wired
36 is wired with black wire
35 is not wired
So what's the problem !
35 is not wired
@flash22 please answer to my question !
I would need to check the schematics what i dont have access to at the moment
The stalk is grounded to the body
So what i need to do to make CCS working on my car
Reprogram the control , activate hidden futures , add new wire ...
Believe me i need it so much 😥
No solution yet ?
Have you tested and verified the stalk and all the wiring ?
I found 12 volt in this brown wire into the steering wheel, the groud from the body
I've check the next brown wire to found 12 volt , i didn't found any result with the first brown wire
I've install the stalk :
the red wire from the stalk to the first brown wire
The black wire from the stalk to the body
I turn ignition on and i press "on" in the stalk , but no result
The stalk after testing show me many different value
In ohm
2 minutes ago, flash22 said:
Does the 12V change when you push the buttons
Cruise button ?
I remove the multimeter when i insert the stalk
I think that the ground must be from the engine control (pin 35)
@flash22
What do you think ?
