Cruise control for 1.0 engine
Seddik
Speed limiter is plug and play, nothing needs activating - stalk 84634-0D010 (base model cars may need a wire to the dash)
newer gen cars have very different ecu's, the 1KR before 2021 in any Toyota does not have CC
Hi! Sadly the P/N you quoted appears to be very rare and on the one shop I found that has it, it's way more expensive than I'm prepared to spend if I'm honest :lol: . I might try buying the Aygo one I found, which, since there was only one stalk ever fitted to mk2 Aygos, appears to be P/N 84634-0H020, if it works I'll report back, and if it doesn't end up working I'll return it... Unless if you happen to know it won't work in which case I'll live without a speed limiter...
Thanks!
For my Yaris the stalk does not appear. I think it only appears for vehicles from 05/2015 on (mine is from 2015 but older). In that case, does the handle shown above still work? I am only interested in the speed limiter function.
it depends on your location and where the car was built
what is the build date of your car ? PM me your vin
The Aygo stalk that I bought for mine (which is a Yaris 1.0 from 2018) does not work. To the surprise of no one but me. :biggrin: The light on the dash doesn't even turn on and there's no limiter function. Don't buy the incorrect P/N!
yep the aygo uses 3 pins (1 and 2 - on/off, 1 and 3, +res, -set and Cancel) and the yaris uses 2 pins (1 and 3)
Linking pins 2 and 3 may work on the aygo stalk so it works with the yaris
Both stalks have the same resistance values for each button
I tried shorting pin 2 and pin 3 together (they happen to be white and black on the aygo stalk) but sadly it hasn't made a difference. Still no light on the dash, speed limiter still inoperative. :sad:
Thank you for your help still.
from the bottom of the stalk Pin 1 is on the right (black), pin 2 (white) and pin 3 (red)
join white with red on pin 3
Sadly that hasn't done the trick either. Not sure what the problem is at this point, I wonder if perhaps my ECU isn't programmed for it, it wasn't an option in my market after all...
can you show me a pic of how you have it wired
Can you PM me your vin
I reverted it back to normal in the meanwhile but I'd shorted the white and red pin on the stalk connector with a piece of solder, detached the white pin from the steering wheel connector and wrapped it in electrical tape as I didn't want to cut up wires. Tested with a multimeter the white and red pins had continuity on the steering wheel connector
PM'ing you the vin
Thanks for your help once again
Have a look under the column at the clockspring plug and post a pic
you should be able to use the Aygo stalk without the need to change the wheel controls (phone buttons)
it's just a case of moving pin 2 (white) on the stalk to the ASL pin on the other 10 pin connector behind the airbag
@turtle15 can you please post a pic of the connector under the column like the one above
@mic12 i have found a possible solution by taking a closer look for turtle the yaris uses a steering wheel button for limiter and the Aygo has it on the stalk it's a case of swapping 1 pin
i will post more info if anyone replies
