charging a 12v battery out of car on a toyota auris hybrid 2013
mervyn4u2
Hi All
Is there any ill effect by disconnecting the 12v Battery in a toyota auris hybrid 2013, charging it and then re-installing it
or it require something else to be done once charged
Only reason to remove battery is cannot get power to car from the house
Merv
Edited by mervyn4u2
question asked was not clear
Strange that nobody has responded to your question. I presume you've got a Mk2 Auris.
I've got a Mk1 Auris (2011 hybrid) & have had no problems having the Battery disconnected for several hours. I haven't had to reset anything but haven't checked to see if the radio presets have been lost. Only thing is that the radio/sat nav seems to take time to reboot so don't switch on & then off quickly but give it a minute..
when i have disconnected the Battery on my hybrid all i have had
to do afterwards is to reset the clock,preset radio stations and the
window 1 touch so there is nothing to be concerned about.
Many thanks both for replies
I understand the  clock and the radio but how does one reset the "window 1 touch"
regards
Merv
if after connecting then Battery back up the one touch window doesnt work then
take the window to the down position and hold the switch for 5 - 10 seconds
then take the window to the up posiiton and hold the switch for 5 - 10 seconds
this should of reset the upper & lower limits of the switch and the 1 touch will work again.
