Outside temperature
Roger75
Hello
I'm having trouble with the outside temperature reading.
Toyota tells me that everything is fine, but I'm not, especially at the moment with temperatures of 38 degrees, I only have 25 on display....
How does this temperature work?
I understand that there is a sensor in front of the radiator, does this sensor go through a calculator or not?
Is it possible to have the wiring diagrams of this sensor and also the instructions to replace it?
Thank you in advance
Best regard
2017 Toyota Aygo
As regards the wiring diagram, have a look on www.toyota-tech.eu
