2010 T27 - Rattling in Steering Column
Northwichavensis
Hello,
my steering column almost seems to slightly rattle through to the steering wheel at around 50mph+.
I’ve had two mechanics look and neither could find an issue causing this.
Wondering if anyone else has encountered this?
Regards
11 minutes ago, Northwichavensis said:
Hello,
Regards
Unfortunately it seems to be fairly common on Toyotas. Column rattle arises from slight play in the splined couplings in the column.  Pulling the coupling apart and applying a thick grease may help.
Sorry, stupid question, is the coupling the same as the u joint?
Do you happen to have any further info?
many thanks
many thanks
No the UJ's are different - although it is also possible for them to be worn on a high mileage car.
There is a splined coupling on the intermediate shaft (to allow the column to telescope on an impact). There is also a sliding spline at the top of the column to accommodate reach adjustment.
