Aygo
Jason Hughes
68 plate aygo
Reversing camera displays but reverse doesn't engage
Clutch is not hydraulic we been told so this affects biting point and also gear changing
Gears sometimes stick
Can anything be doneor any advice re above please
i am only going to state the obvious take it back to toyota
as it is probably an internal issue with the gearbox since
the reverse light switch is working
Isn't it still under Toyota warranty?  Take it back to them let them fix it.
68 plate should have a warranty, you shouldn't be experiencing problems like that. I echo the others.
