Charging fault
Dennis Hayes
Hi new to this forum i have a 2016 avensis (bmw engine) . Car charges @ 4.2 volts for 5 miles then stops charging  turn on sidelights voltage goes to 41.2 then drops to 13.5 . In cold weather -10 will charge ok 14.2.Car is a taxi it has had a new alternator and Battery fitted did not cure fault . It is fitted with a taxi meter when disconnected it does not make any difference it is linked to the can bus set up.All earths have been cleaned can any one help thank you all in anticipation. Dennis
