fuel vapour feed hose replacement
600rob
i need to replace the fuel vapour feed hose shown here on my yaris as the existing one has split and is causing some sort of vacuum leak
https://www.megazip.net/zapchasti-dlya-avtomobilej/toyota/yaris-echo-vios-limo-42478/scp10-57196/scp10r-chmrkw-927624/vacuum-piping-17944048#/il-415312754-3866737-3866737
is it okay to just replace with the appropriately sized regular fuel hose correctly routed? or is it important to use the correctly pre-formed section of tubing? since im sruggling to find the actual part available online in the uk
I guess this question applies for all hoses that are pre-formed. Im guessing that if it doesn't need to go round sharp corners the a regular section of hose could be used right??
in my case i could just bend a bit of regular pipe to fit without there being any sharp bends or kinks
As long as it doesn't rub on anything a oil/fuel grade hose will do
I take you have done a smoke test to verify the issue
