I need to replace both drive shafts for my Vvti 1.6 2003 Verso ZZE.
But apart from main dealer parts which cost more than the value of the car I have sourced replacements. But there is no way of finding whether the inner spline which fits into the gear box has 20 or 23 splines without removing the old shaft first. In which case it’s a gamble if I have the right part.
Is there any way of identifying the correct shaft ? I have the Toyota part number .
Cheers
The OE part numbers are
43410-12660
43420-13051
But the factor has no way of identifying whether the shaft has 20 or 23 splines
Cheers
You will have to disconnect one to be sure,  beileve the 20 or 23 refers to the Transmission end and not the Axle end which is different again.
Seems you can pick them uo for around £115 from motor factors like GSF or sites like the AutoDoc, EU who do them even cheaper, though as others have said they can take some time to arrive, depending on actual stocks.
eBay has them even cheaper but no mention on the number of splines ..
https://www.gsfcarparts.com/parts/transmission/final-drive/drive-shaft
https://www.ebay.co.uk/itm/FITS-TOYOTA-COROLLA-VERSO-1-6-VVT-i-1-8-VVT-i-PETROL-DRIVESHAFT-NEAR-SIDE-01-04/131701818983?hash=item1eaa0a4667:g:f-cAAOSw9gRaPZla
Thanks,
The ones I have bought have 20 splines but I was hoping to avoid having to put the car together again if I found the gearbox had 23 spines, then re order.
Cheers
No real need to change the inners as they rarely fail, remove the old inner cv boot, remove the shaft (just pulls out), clean out the cup and check for wear, fresh grease, slip the new one in and add grease
it's usually a 3 bearing design
Edit abs or non abs ?
43420-13051 comes back as a 23 inner and 26 outer
43410-12660 comes back as a 23 inner
23 spline is for the ZZE121, 20 Spline is for the ZZE122
What are the part numbers you have been supplied ?
Edit 2. 20 spline is for the automatic (5 speed automated manual ?)
Really appreciate your advice.
They have supplied me with a 20 spline which appears wrong according to Bob as I have a ZZE 121 R -FWMDW(1B) Version of variant ZZE121 (W).
It’s a 1.6 5Speed  manual.
Grateful you advise whether I return the 20 spline and request a 23 ?
many thanks,
Steve
In reply to your question Bob the car does have ABS
The numbers you have been given are correct going by the model code given
the 20 spline are a different part numbers
43410-12670
43420-13061
you can cross-reference the parts on sites like autodoc, etc
Really appreciate all your help Bob it’s been invaluable and will reduce the time I am off the road.
Cheers
Steve
The replacement 23 spline shafts have arrived And I have checked the number of splines
Is there any other checks I can make of the driveshafts before I hand them to my indie next Tuesday when he returns from holiday please
Many. Thanks again.
Cheers,
steve
