Toyota avensis diesel
Believer
 Hello new avensis owner
I have a problem no brakes took rear passenger wheel off everytime brake pedal pressed brake fluid tiny pinhole squirts
How much to repair bll Park figure pls
Any help greatly appreciated not mechanical at all
As from picture see pinhole squirt love my avensis just would like some sort of figure roughly or is this easy to replace
You shouldn't drive that car.
It might be better if you got a mobile mechanic to come to you.
I have no idea what the cost would be, it would depend on what they wanted to do.
Is it all in one section or can it be split and don't worry will not be driving until fully sorted!
That pipe goes to the front of the car.  I split mine and only replaced the piece at the bend.
Sounds like could be a very expensive job I really appreciate the feedback was so at a lost end thanks u
It's only two brake pipes (I assume the other side needs to be done,too) it won't be the end of the world.
  • 2 months later...
Very common problem due to dirt collecting under the fabric wheel arch. Had the same issue when my OSR brake pipe ( atexactly the same point!!!!) corroded through. Ended up replacing the pipe from front to back due to the original brake pipe is steel and trying the flare steel pipe is a real PITA (I'm a mechanic and tried various times on numerous cars and failed every time!!!!) so a full copper pipe replacement is fair easier. But fiddly to get round the tank my there is room.
