Headlamp not burning bright
My one headlight on driver side won't burn bright. Fuses are checked replaced bulb still same problem. The brights are working thou but the normal headlight won't work properly almost looks like it is just on park. I
Correct bulb fitted? Maybe a defective bulb? I assume you mean the dip beam isnt working? Swap bulbs with the other headlight?
