Need help wiring my audio system in
Kizzy677
Tell me you didn't hack the factory connectors off
what car and year ?
The above still applies
if you want to replace the original connectors the cheapest way is to get a SOT lead to cut up - Connects2 CT10TY01
you will need a multimeter to work out what wires are what
Ahhh ok so ur saying I can get the SOT lead and use the things I need to get the original connectors back, the wiring may be an issue will it require soldering and how do I know which connectors I need
