Hi
I'm in the process of replacing the master cylinder on my 2005 2.0 d4d and after removing the pin that attaches the cylinder to the clutch pedal, that's held in place with the clevis pin, I noticed a really worn kind of plastic sleeve. Is this for the pin to go through and does anyone by chance know the part number so I can buy one
Doubt anyone other than Toyota will stock those parts,  youi need to contact your local Toyota dealers spares dept, who will establish the right part number based on your reg no /vin.
Usually takes a day ot two for them to order the parts up.
Thanks, did just that. £2.30 which isn't too bad and got a diagram printed off with the oe part numbers off them as well.
