Using factory fitted Auris rear camera to Pioneer DA230DAB
fawadsabir@outlook.com
Hello,
I have purchased a pioneer da230dab unit with CarPlay.. everything works fine and im loving it.. DAB, steering wheel controls etc all work fine.
I am struggling to get the factory fitted rear camera working.. i have connected a 16 pin connector with an RCA socket to the back of the pioneer but struggling a bit to understand where the ground or accessory power go..
Also there is a mention of having to drop the voltage down from 12v to 6v -  i have read around that this is a requirement for a subaru, but not sure on the Auris.. anyone know the answer?
You will need a camera retention adapter
Mk1 or mk2 auris
CAM-1TY-RT 16 PIN
CAM-2TY-RT 24 PIN
sounds like you have one already or made one, power and ground tap the stereo wiring the adapter has a built in voltage reg to drop the power to 6v (5-7v tolerance)
Thanks for this...
Yes I have this (images attached) - it all seems self explanatory to be fair.  I guess i chop the yellow and feed that to the power and the black goes to the ground.. see attached photos.
But where im a bit dubious is the need to drop the voltage - i cant find any details about what voltage the auris camera is.  I know the pioneer will give 12volt, so there will be a need to drop i assume..
But can someone clarify, and also any idea how i can drop the voltage?
Mk1 or mk2 auris
CAM-1TY-RT 16 PIN
CAM-2TY-RT 24 PIN
Hi Mate..
Thanks for your response - i have ordered the adapter and also the voltage dropping thingy.. i suspected that all i needed was the cable i got, but it never so had to order that too:
ttps://incartec.co.uk/product/12V-to-6V-voltage-converter-for-reverse-cameras
At £30 each it wasnt cheap.. wish i had gone down the route of adding a third party one.. but hey ho.
thanks - ive ordered the alternative cable.
Many thanks.
if you have already wired up and tried the camera you may of blown it with putting double the voltage through it.
Nope.. not connected it so fingers crossed all should be good.
Hello..
Me again - this is started to frustrate me.  I have received the retention cable and connected everything as expected however im a bit confused.
Ground cable is connected to the ground cable.
Reverse switch cable from the back of the pioneer is connected to the head unit and not to the retention cable.  This works as expected and when i put the car in reverse the screen changes over but no video shows.
Any idea where im going wrong.  Im not sure if im supposed to just leave the reverse switch cable disconnected from the retention cable.
I have put in the old toyota unit to check if ive not blown the camera and it works perfectly on there..
Any ideas?  Ive attached some photos
So after spending alll morning messing around with the setup this morning i have now got it working.  I had to use a mixture of a incartech retention cable along with a 12v - 6v transformer from the connects2 cable and it works.  I think the pin outs on the connects2 doesnt have the correct pin outs or was faulty.. but yes it works perfectly...
  • 11 months later...
Hi Fawad,
I have the same problem with my 2010 hybrid (but different head unit) - all seems to work but just no video!
Could you share what you did to resolve the problem please?
What adapter have you used, what model was the factory head unit ? As above, the factory camera uses 6V (5-7v)
Early cars use the 20 pin for the camera later cars use the 16 pin and some have an unusual pinout
Socket view or wire side of the plug
1. 6v
11. Ground
2. Video +
12 Video Ground
  • 7 months later...
I have a Auris Excel with reversing camera and have been installing a Sony Head unit.
The connects2 main kit CTKTY08 worked okay (no drilling or cutting required, discard head unit DIN cage) but does not provide the dab aerial connector or support the use of the factory fitted USB socket.
Also of course no cable for the rear camera and having the 16pin socket got the CAM-1TY-RT
However, on trying it the head unit Sony XAV-AX3250 switched okay to the reverse camera but reported no video signal
Thus I checked the voltage at the regulator for the camera supply. 12v in and nothing out. I then noted it was getting very hot!
On further investigation on a page called "Subaru & Toyota OEM Head Unit 16-pin Rear Camera Input How It Works" it seemed to me that the output polarity was wrong feeding the rear camera.
Thus I swapped the wires around hoping the reverse voltage had not damaged the camera and yes it actually worked 🙂
I may have just had a one off unit wired wrong or perhaps they all ship this way.
I have a 28pin (male to female) cable on order to hopefully add parking break support (needed for Android Auto setup) and cables for the USB and DAB. I will report back when they arrive and if they work (coming from the USA and China).
  • 1 year later...
Just came across this thread after I posted one about how to wire a reverse camera retention adapter.  I had to buy a CAM-2TY-RT 24 PIN adapter for my Auris
May I ask which wires from the retention adapter you actually spliced into, please?  Do I need to splice the cables from the retention adapter to the factory harness, Pioneer adapter Loom, or the Connects2 Loom?  I'm just a bit confused about where they should splice into.
Thank you.
pick up the 12v reverse signal to power the retention adapter, it should be on pin 2 on the 28 pin
This is the socket view or cable side of the plug
Pin 2 - either red or brown
if it's not fitted, you can find the reverse signal at the Instrument panel junction box behind the glove box or use a can bus adapter
https://www.connects2downloads.co.uk/C2/files/InstallationGuides/CAM-TY2-RT.pdf
Ignore the reverse wire on the Connects2 CAM-TY2-RT it's not used in this application
I don't seem to have anything on pin 2 on the 28 pin connector.
Could I just match from the retention adapter, red to red, black to black on the Pioneer loom and then attach the brown wire to the pioneer reverse wire coming out of the unit?
Pin 2 should indeed have the reverse signal. Are you counting the pins from the correct end / row, some images seem to cause confusion.
That then feeds the CAM-1TY-RT and the camera (from what I recall).
New op has his own thread, up to mid 14 had the touch system what has the reverse wire on pin 2, after mid 2014 the radios changed to the touch2 that uses a can bus reverse signal
  • 8 months later...
I have an Auris 2 2014 sports touring. Originaly with an touch & go 1 system.
I installed an Android head unit. but the rear camera is not working.
I have bought this cable. https://nl.aliexpress.com/item/1005004674918629.html?spm=a2g0o.order_list.order_list_main.5.21ef79d28oaobD&gatewayAdapt=glo2nld Is that what i need to get it working?
The radio https://nl.aliexpress.com/item/1005006665369834.html?spm=a2g0o.order_list.order_list_main.11.21ef79d28oaobD&gatewayAdapt=glo2nld wire loom has an yellow video connector. But where do i connect the others wires to?
And is the rear cam 6V or 12V?
Hi Rick !
  Your camera should work with this adapter.
  The camera works at 5 or 6v, but adapter cable includes a step down module, 12v to 5 or 6v. You need only to connect those two wires, black to the ground and blue to reverse lamp positive wire.
  You need a voltmeter to find this reverse plus wire, it's possible to find it somewhere in radio connectors, otherwise you have to route a new wire from the reverse lamp in the back to your new stereo.
Hi, sorry to resurrect an old thread but I'm hoping someone can help me with a similar issue!
The car is a 2012 Auris (one of the last old shape)
Here's the head unit:
Here's the back:
As you can see from the last photo, I've had a Sony XAV-AX4050 fitted.
It was done at the local Halfords who were pretty efficient and tidy, but when I went to pick it up the fitter hadn't realised that a reversing camera was fitted and the relevant cable needed.
To be fair he apologised and looked on his system to find a cable but there was nothing available from his supplier. He did say if I can source the correct cable he will then fit it for free.
I'm home now and looking at all these ports and I have no idea which one is the relevant port, never mind looking for the correct cable!
I'm thinking I need "CAM-1TY-RT 16 PIN" but I would very much appreciate if someone could confirm for me.
Thank you in advance
its an early Toyota touch
it's on the 24 pin what requires cam-ty2-rt
4 minutes ago, flash22 said:
its an early Toyota touch it should be 16 pin, have a look at the plugs in the car the 16 pin plug should have 5-6 wires
if not, it's on the 24 pin what requires cam-ty2-rt
Thank you, the problem I have is that the new unit has already been installed, so I can't see the plug any more!
From the older posts it looks like the TY2 is the newer model Auris (2013-)?
May be I'll have to buy both leads and let the installer sort it out, not ideal but if there's no other way 🤷🏽‍♂️
Rather than take the risk I went back to Halfords and got them to pop the new headunit out. In case anyone faces a similar issue in the future, here's the connector for the rear camera, 16 pin:
it's an early one, the camera is on the 16 pin connector - CAM-TY1-RT
