Verso-s front bake caliper torque settings
Morning , after some help on torque settings please.
All through lockdown and for a while after we left our Verso SORN as we weren't using it, I did start it up and drive it backwards and forwards a bit to keep things moving but the front brake discs did rust up a bit. Post lockdown we still get a grinding noise when braking and on the passenger side it looks like the disc is beginning to score just a little bit.
I want to remove the pads to make sure there is nothing stuck anywhere but don't have the Front Brake caliper torque setting to re fit, apparently there is no Haynes manual ( according to their site ) so I can't buy one of those.
Any help would be much appreciated
Andy
This topic has been posted in the Verso-S club.
Is it the Verso you have (as per your profile) or the Verso-S as per the topic title -
Verso:
Verso-S:
Two very different models.
Hi, it's the Verso-S. I did have a search for the torque settings but couldn't see anything for it, but will have another look.
Have updated car info 😉
Andy
Caliper to bracket or bracket to hub ?
Hi, It would be the Caliper to bracket as I just need to release the caliper so I can remove the pads to check nothing stuck between the pads and the disc.
Andy
25-30 Nm, what is pretty much the standard for slide pins
Brilliant, thanks for the assistance 🙂
Andy
  • 9 months later...
Andy
Hope all well and you sorted I am looking to do the same would appreciate some help on below
1- Wheel Torque
2- jack point Is it only 2 notches
3- Grease for caliper pins.
4- Would appreciate if you can list any other materials
There is a lack of documentation I am thinking to upload something here for other users once finished.
For brake caliper Pins Is it 17mm
mm?
PHOTO-2021-06-10-19-20-59.thumb.jpg.54a02cba8a8310b40e2f423421068153.jpgPHOTO-2021-06-10-19-21-00.thumb.jpg.f9167bc5c08ce17bcba86ad704a12d74.jpg
Sorry its 14mm size for caliper.
I was wondering if someone can help re the front lift point its not clear in the manual
The jack supplied with car goes inside the notches is this correct ?
