OEM "rubber" hose on early 2gr-fe engine with rubber VVT-i often fail. After several years the manufacturer replaced it with solid line. Earlier year owners often swap out the rubber for the later year solid. This is too involved for me right now, so i was just going to get the best high temp high pressure "rubber" hose and good clamps and inspect it often. Then i thought maybe some Wire braided hydraulic hose?
I know that then my end clamps would really be my weakest component, so maybe im going way over kill here.
In this application the hose is located between engine components with not much air movement and is also subject to pvc gases.
dels. Im dealing with a 2007 avalon which from what ive read is the most involved when replacing the entire line with solid. There are additional reasons that id rather not replace entire line now.
Thoughts?
Tks, pa
Toyota Owners Club is UK based - the majority of members are in Europe. Europe never had the Avalon, and only started receiving the Camry again in 2019 after a 14 year gap. So comments may be limited.
