Warning sound if engine on in P and open door?
Does a warning tone sound if you leave the hybrid system (engine) on in Park mode and open the door? Does it stop if the door is closed after exiting? Can't find in Owners manual (car not delivered yet). Ta
EDIT: e.g. if you want to pump your tyres up using a portable compressor plugged into the 12v socket - you are going to want the hybrid system on to not drain the 12v Battery.
Hi yes the warning stops if you close the door
When pumping tyres, I leave the car in Ready mode. With my last ICE car< I always started the engine when pumping the tyres, so i treat the Hybrid the same way, especially as the 12 volt Battery is a light weight compared to the Battery in an ICE.
I have a foot attached to my leg for my pump
  • Haha 4
