2016 Yaris seat adjustment issue
z1ppy
We keep having issues with the adjuster on the driver seat. My partner and I share the car and as i'm significantly shorter we slide the seat backwards/forwards every other day. Unfortunately it keeps getting stuck in position. We've been back to Toyota now 3 times in the last month to have this fixed but it's just gone again today! Does anyone know if there any longer term fixes for this or whether Toyota should repair under warranty?
Thanks 🙂
A bit of lube will make it slide a bit easier
a lithium grease should do the trick, also make sure there is nothing in the tracks or under the seat
That's wide open to smutty comments, but I will resist.:ph34r:
