T29 tire sensors
matthewws
Hi All,
I do have a petrol 1.8 toyota avensis station wagon from2017
I’ve bought a new winter tires set with tires and sensors installed.If I put new set in to the vehicle would be possible to read serial Numbers through Toyota Tech and than register as second set in to the computer or i need phisically copy Numbers from sensors and then te-type in to the car computer?I do have a cabel with toyota teaxh stream
I don't have TPMS, but still did a quick search and the following -
 Read the last post. You will need to see what your car supports!
