Mk1 Yaris Steering Wheel replacement
PixelGoat
Anyone know of any good kits for a steering wheel replacement on a Mk1 Yaris? Wanting to get something rather sporty to replace the stock wheel.
The big problem is the airbag, it will put the light on (easy enough to sort) and you need to see what your insurance company say, and if they will even cover it as it's classed as a safety device
you could fit a leather wheel from a high spec car or T sport if you have the basic vinyl one
eg. https://www.ebay.co.uk/itm/TOYOTA-YARIS-2005-1-3-VVT-i-COLOR-EDITION-3DR-STEERING-WHEEL/402382094106?fits=Model%3AYaris%2FVitz&hash=item5dafd77f1a:g:SScAAOSw3ZRfROva
Insurance could be a nail in the coffin for this project. will have to get in touch.
In regards to OEM steering wheels I have the one listed, I'm more looking for an aftermarket one if that helps
Haynes say"
. Disconnect battery -ve lead.
Leave at least 1 minute.
Revove airbag (see below)
Disconnect earth wire at top of steering wheel
Ensure wheels are pointing straight ahead and lock steering wheel in this position
Hold rum, unscrew nut
Remove wheel from splines
Airbag
Lengthy description in Haynes.. Borrow a manual.
3 hours ago, Madasafish said:
Hold rum,
I suppose you need a stiff drink when dealing with airbags 😉
I need a stiff drink dealing with windbags..🤒🙁
  • 11 months later...
Would any of the later yaris steering wheels fit a t-sport?  I have just bought a Ph 1 T-sport and would be interested in seeing what else could be used.  What about the Ph2 with the steering wheel controls?  How could that be made to fit and the controls to work?  And do the later wheels have the same spline size?
On 9/7/2020 at 10:47 AM, Madasafish said:
unscrew nut
And do not remove completely until the wheel is loose on the column. There have been many broken noses, teeth etc. caused by removing the nut completely and pulling hard on the wheel!
  • 3 months later...
Just picking this up again, would a Mk2 steering wheel fit a Mk1?  Are the splines the same? and is there a harness to connect to the clockspring?
thanks
I can't imagine it fitting, they look very different...!
Never taken either apart tho' so can't say with any authority...
