2011 T27 Avensis. Car stalls on gear mode
andrewjumba@yahoo.co.uk
I often find it very hard to drive when I start my car, All gears works fine. After a 2minutes drive the car stalls when it has warmed up and the engine is running but no reverse or drive is working when engaged. it's like on neutral.
Any ideas what may be causing this?
Regards
Andrew
If I change TOYOTA K311 CVT AUTOMATIC TRANSMISSION GEARBOX SOLENOID NEW SET KIT will this work or i need a new gearbox?
Look at the following. I will look for the auto version.
