Front fogs 2008 model
Grissgray
Hi all I have fitted a set of fog lights to the front of my 2008 Avensis
Plugged them in using the stock wiring and fitted a new stalk to with the front fog light switch on it ( I took them out of a spare avensis I have )
I have read up and I can see that the front fogs and the indicator's use the same fuse
can any help me get these work is there a relay I am missing                               thanks
If you have a spare Avensis, you should be able to compare fuse boxes etc to see if they have their own relay, which they probably will do.
I have compared the fuse boxes the are the same, when I look it up online there's ment to be a relay holder behind the glove box with 4 relays in it one of them is the fog relay but I can't find it, any ideas
So what all did you need to put in the fog lights .I am gona to do mine 2008 model
I am watching this with interest as my headlights are still crap after fitting so-called better bulbs. Maybe fitting extra fog lights is an answer but how do aftermarket lights fare at MOT time?
