Hi can the diagnostics be checked on my car with a computer or any device i have a 22 pin connection..
You have to "flash" your error codes out onto the dashboard display.
If you search the web and ytube you will find lots of examples, basically its a case of a piece of wire connectiong 2 pins of the socket and watching the engine check light flash out a sequence of numbers which you then match against the error code list.
The easiest way to Clear the stored error code/s, is to disconnect the Battery for a few minutes.
https://www.youcanic.com/guide/read-toyota-obd-engine-codes-without-scanner
https://www.youtube.com/watch?v=RE6EZYJAOHE
https://www.youtube.com/watch?v=RiYkHicqs3A
