Halligen Bulbs
mrrandom
hard to fit! the one on drivers side is a piece of ***** to fit! but one on passenger side is hard, bcoz theres no way you can get your hand in there! the Battery is in the way and sumthing else.
hadta take it to toyota and they fitted it. cost 15 pound to fit one bulb :o the bulbs only cost 14.99
either remove the Battery or just undo the 10mm bolt on the air pipe to make more room
I didnt do the above on my car, ended up with loads of marks on my hand
u tried it? one on passenger side? right !Removed! on, gota take disconnect Battery and take it out!
bad layout from toyota me thinx!!
its not a "bad layout" they are just using up all the space
Whichever way you go about it, remember not to touch the glass of the globes with your bare hands as it will cause the bulbs to fail prematurely.
Using a plus 50 bulb myself
The bulbs will blow prematurely if they have any marks from fingers etc because the bulb then cannot radiate the heat properly leading to an increased internal temp and therefore early failure.
If you do touch the bulb make sure you clean it throughly will a soft cloth so it's totally clean before you fit it.
I have a set of OSRAM Silverstars installed. They are noticeably brighter than stock. Money well spent. ;)
either 5000k or 6000k, cant remember
THEY ARE ILLEGAL (as it says on the package)
has anyone got pics of their yaris with stock headlights or non bule or white
There illegal due to the colouring. Front lights by law have to be white/yellow so blue is well... not included.
not just that, bulbs must not exceed 60W where mine is 110W,
on a plus side, these let you see better and they look good
the bulbs are easy as pie to fit!
except passenger side
Ah, where you the :censor: who was blinding me the M1 last night then?!
nope, there is usually no-one in front of me on the highway, I usually make sure they use the middle lane. I was only on the M602 last night
