Buying a 2010/2011 Avensis - problems + towing question
Ranoid2000
Hello all,
This is my first post so  go easy!
I'm looking into buying an avensis around a 2010/2011 with a £5k(ish)  budget, preferably an estate which will be used to tow a caravan.
After being stung with large repair bills (£600 for one diesel injector) on my current 2009 VW Golf Tdi, and the fact I do low mileage (6-8k a year) I think im decided on a petrol model.
Is there anything particular to look out for in regards common problems for when I'm buying?
Also has anyone here uses a petrol + auto for towing with much success. I quite like the idea of the autobox and they are quite common. Are they bullet proof or troublesome?
Thank you all in advance
Ranoid
Petrol would be best for you.
T27 series Avensis use a CVT auto. They appear to be reliable but not the best for towing.
Used car prices are very high at the moment and there is a shortage of stock. Wait until the New Year if you can...  you'll probably find prices take a dive.
Realese when you buy the car. The owner has a unlock key for the towing hitch. I bought my car without a key. Then i got a copy of it key.
Thanks for the replies.
One thing i have noticed is quite a lot of cars seem to have as advisories , corrosion on subframes and other expensive sounds things when checking MOT history. This is on 09/10/11 plate cars.
