2 hours ago, marcb256 said:
Hi, my first post. Have just exchanged my Exel for a GRS as happy with the Corolla. Obviously the majority of things are the same but my one big disappointment, though a minor issue in the scope of things is, there is only 1 USB port. Pretty limited thinking.
With the Exel I used a low profile stick in the USB beside the glove compartment and charged the phone with the USB beside the driver.
Now I have to go and find a power socket with a USB to charge the phone from. The more I write the more annoyed I get as to why someone decided to omit the second USB.
Gripe over, I think as I've only had the car a few hours.
Don’t look for the rear vents then!!!!
  • Haha 1
16 hours ago, Roy124 said:
Is there a 12v socket in the centre arm rest?
Yes but before there was a 12v socket and a USB
Unfortunately in UK that is Excel hatch & all Touring Sport (Estate) models only
Mine is Design.  It must have cost time and effort to design it out.  I haven't had a close look, but there seems space for the USB.
Just did and can't find them !
  • Haha 1
Yes, there is a blanked out space. Luckily I kept my 'old' tech so have a power connector with built-in USBs.
  • 1 year later...
I had an issue with my 2019 Corolla and found out that any memory stick which isn't formatted to FAT32 for music.  All of my music is in FLAC format (I didn't want to have to convert it down again) so 64Gb memory sticks were needed. I found a utility by HP that allows you to format any size memory stick to FAT32 ( https://www.bleepingcomputer.com/download/hp-usb-disk-storage-format-tool/ ) solved my problem.
I've just taken delivery of a 23 plate Corolla, I now need to get a converter for the USB audio port as it's now a USB C will keep you updated when I get an adapter.
£4 something from Amazon buys a set of USB C adaptors. Just the job.
I have an adapter from USB C TO USB  and all works as it should with a USB stick. No worries.
Thanks for replying really appreciate it have ordered some right angled converters.
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
