Code P 0171
Daviem
Hi All, hope someone can help, keep getting code p0171, changed both O2 sensors, MAF sensor and air filter but, the code keeps returning after about 30-40 miles.
This is on a Yaris 1300 T Spirit 2011 plate
Regards Davem
It's more than likely a vacuum leak, A smoke test will be the easiest way to find it there are other methods, but they can be hit or miss
i see you have shot gunned parts at it
Regards Davem
Do you have the freeze frame data from the P0171 code?
