Injector problems
JonnyG123
I have a 2008 toyota auris SR 2.0 d4d 120,000 miles it got an injector rattle, problems starting etc etc i dropped it to my mechanic got all 4 injectors fully refurbished the whole fuel system checked ie sensors, pumps, injector driver, and its still not starting first turn of the engines the injectors spray then after that they stop and build up pressure and blow the fuel pump and he is under the impression it could be the ecu? Any help or hints would be appreciated
This is not 1992, he should use diagnostic tools, not guess. Maybe consider another mechanic who is more skilled with Toyota diagnostics.
