Front Brakes Squeaking while braking
jacsll55
My Front Brakes Squeaking while braking took it to the showroom and they took them off cleaned with brush and have tested on a MOT bay for brakes and said its fine, but still the squeaking continues.
I have no experience of this with Toyotas, but on other cars I have overcome this with a light coating of brake grease on the piston faces.
If shims are used between piston and caliper, I coat both surfaces instead.
Might simply be the compound of those particular pads...try a couple of emergency stops (safely.!)..see if makes any difference.
Worst case scenario is a different set of pads perhaps.?
