All New Yaris 2020 help
YarisOAP
On old 68 plate Yaris you could setup a over speed where the lady would say you are going to fast cannot seem to find on my new Yaris Hybrid Design
its part of the nav iirc under map settings "Audible warning, if limit exceeded by:"
https://d24bc9lyrt5en5.cloudfront.net/Customer-Portal-Admin/emanuals/TOYOTA/OMK0019E.pdf page 103
you also have safety sense and limit via the CC controls on the wheel
https://d24bc9lyrt5en5.cloudfront.net/Customer-Portal-Admin/emanuals/TOYOTA/OMK0001E.pdf  Page 220 onwards
New Yaris in the UK is not equipped with factory navigation system, Navigation is only supported via only Apple carplay /Android
Page 226 of Full Manual ( downloadable Via MyToyota ) describes how overspeed warning is available via RSA Road sign assist. These settings are via steering wheel in the Speedo main display and functions are limited as it can only operate when the RSA has "seen" a sign.
The manual is from Toyota's UK site so an oversight on Toyota's admin
So am I right in thinking it cannot be done in Apple play Sat nav
3 hours ago, YarisOAP said:
So am I right in thinking it cannot be done in apple play Sat nav
The function would have to be part of the App you choose for navigation, it appears that :
Google maps supports an onscreen speed limit and overspeed display ( can't find any info to say its also audible )
Waze has onscreen speed limit and overspeed warning plus audible
Apple maps has onscreen speed limit but can only find info that overspeed warning is rolling out not sure about audible
Owners manuals are fairly universal across trims/specs and will certainly contain instructions for features and functions not available in all models and should definitely not be used to determine what spec a car may have.
