Auto gearbox
Mylo1
Hi can anyone give me some advice about my auto gearbox. Driving tonight I heard a bang then banging like a metal bar Hitting under the car repeatedly and my gearbox packed in no life at all and no gear selection but grinding noise when I put it into park. My car is a Toyota avensis 2011 2.2 auto est 110000 miles
any help much appreciated thank you mylo
Your car has a CVT.
First check for a broken driveshaft/CV joint.
If the driveshafts are intact then maybe that the gearbox has suffered an internal failure. Secondhand replacement would be the way to go...
On 9/22/2020 at 12:44 PM, mrfixer said:
Your car has a CVT.
Jim is right about checking the driveshaft. The auto gearbox on diesels is conventional 6 speed auto. The CVT is only on the petrol engines, not the diesels.
I suspect the driveshaft because the description given. It is the cheaper and quicker fix, so the lesser evil. 🤞
Agreed with the driveshaft diag, maybe be a failed cv joint (tend to fail while turning and pulling away)
If one drive driveshaft fails you will lose all drive
