Infotainment touch &go buttons on different sides
mikmikmikmik
On the RAV4, the buttons on the head unit are on the opposite sides to any pics I gave seen on eBay or in the radio user manual.
Example:  The setup button is bottom left instead of bottom right.
Anyone got any idea why this is?
That's a question, but mine is a RHD UK model, unless they changed the unit under warranty at some point in the past. I don;t see any mention of changing the head unit.
An image for the Touch & Go from Toyota UK blog shows the on/off button on the right
An image from Toyota Europe for the Touch 2 & Go shows the on/off button on the left -
This one shows the way mine is:
https://www.ebay.co.uk/itm/Toyota-Europe-2020-v1-Touch-n-go-map-update-Verso-Rav-Prius-Auris-Avensis-Prado/233514669857?hash=item365e8f1721:g:N4MAAOSwSN5d0FzI
I just did a look on autotrader for cars of same age and it looks like this is model 510110, according to the little number bottom right of unit. The units on Autotrader also have the same button locations, so I think all is OK.
Thanks for any replies.
Yes, that's the one (510110) fitted to mine so you don't need to worry, you have the right one.
