Toyota Yaris Icon Tech navigation update?
sufy
33 minutes ago, CPN said:
You'll have to use another program as said before...
yes i did use guiformat and it did format to FAT32 but when copying the file to the usb drive i can't do it as it says it's too big.
29 minutes ago, martswain said:
@CPN
I found that out the hard way, but GUIFORMAT is a free download and runs without issue on W10.
@sufy
Once you have formatted the USB drive, make sure it is empty.
Extract the files to a folder on your desktop, then copy the CONTENTS of that folder to the USB drive.
are you talking about doing this on the FAT32 format?
Format the drive to FAT32.
From the ZIP folder you have downloaded from Toyota, extract the files to another folder on the desktop.
Cope those individual extracted files to the USB drive.
The files I have shown you in my screenshot are only a total of 4.72 GB on the drive.
The files you need are shown in my screenshot above.
Edited by martswain
ADDED INFO
Sufyan, I have no idea how proficient you are with Windows but try this...
1. if you are looking at that image that Martin sent above, select (highlight) the "nav" folder.
2. Press CTRL and A together on your keyboard. This will highlight all the files
3. Right click on any of the highlighted files and choose "copy" from the menu
4 Navigate to your empty USB drive
5. In the right hand window fo file manager (which should be empty), right click and choose "paste"
6. You're done
Yes mate! it worked. Thanks. Now hoping it recognises the usb in mi car lol
6. You're done
Thanks. Doing this now.
Remember, you must keep the vehicle fully switched on and running for the whole time the update is running and that can sometimes mean 40+ minutes for all the maps.
will do mate. Thanks
7 minutes ago, martswain said:
I hope this soap opera has a happy ending !
Hopefully it should be 😁 I'm gonna try tonight.
It worked! Thanks to everyone who helped me out. Appreciate it 😀
Can i also update the software? like to a newer ui?
Previously i had version 2018 V2 but now it's updated to 2020 v1. Is there a difference between version 1 and 2?
Toyota give two updates a year V1 & V2 just denote Spring map release V1 Autumn V2, 2020 V2 will be coming soon.
I made that mistake, luckily it completed the update fine upon second attempt.
