E12 t3 not picking up signal from bank 1 lambda sensor
Hi, any input would be appreciated, my 2004 corolla 1.6l petrol engine code 3zzfe, denso ecu is having issues picking up signal from bank 1 lambda sensor, despite having full continuity in wiring from lambda to ecu multiplug, and has a new known good lambda sensor, it has been checked multiple times. Its coming up with TDC: P0125 insufficient coolant temperature for closed loop fuel control. Its running extremely rich. Anyone had any trouble with these?
