Vibrations clutch pedal
Neonistheo
ood evening everyone and thank you for accepting. After changing to aisin clutch set in yaris d4d 2008 I notice at the high speeds of 2.500 revs  and above a vibration when I press the clutch almost all the way. The engineer mentions as a problem the filter box that over time has relaxed and transmits all these vibrations. Have you had or do you have a similar problem ?? thanks
