Programming a fob from a different Yaris
Skiny
So, I have a black Yaris for scrap, with the black remote fob/key and the grey slave key. New daily Yaris came with 2 black keys that I'm assuming both have the chip inside as both open/start it but no remote fob for it.
So the question is can I program the black cars fob/key to the new daily  ?
Both are 2001 cars
100 odd views and nobody knows 🤷‍♂️
Anyone lol
Engine and ECU and loom is out and starting into the dash tomorrow,  do I need to swap the keys etc ?
Once a key is programmed to a car it cannot be reprogrammed to another
The key isn't programmed to the car, the car is programmed to the key.
Sounds reasonable to me.
We have a security issue here though, but if you have a key and you have a car, they should ................ with the right software and with the security in mind ................ they should be able to be united.
A car gets scrapped.  The keys and locks get scrapped too.
Let's say that the car gets scrapped but the keys and the electronics are salvaged.  How can they be reunited in another vehicle?  It must be possible, so therefore it must be possible to get an "old" key to match up with a "new" car.
Mick.
Above answers are wrong the key is programmed to the cars ecu, it is possible.
They can either be programmed through Toyota techstream or manually by following the programming procedure which can be found with a quick search.
When pairing a new key, you are instructing the car's ECU to accept the identity of the new key.
Exactly.
The key is only a slave device, but the car's ECU is a computer which can be programmed.
Mick.
Thanks for the replies folks, doner car is stripped to a Shell, front end loom the lot 🙂
can anyone point me in the direction off the programme guide, opening and locking it with a key is so annoying lol
it's a gs so it has got central locking
Did a search but cant find the programming guide 🙄
Have removed the central locking ECUs and transpontransponders so if I cant get a guide it should all just swap over......
Hello Neil 🙂
