Sporty Exhaust & Air Filter ---------
Hi all,  another question here!! Do you all recommend a sporty looking twin pipe exhaust and airfilter to help the car breath and look good at the rear, if so whats a good exhaust system and air filter?
Also would there be a difference in performance wise, i know they are only 3 pots in the engine but are there any noticeble gains that can be squeezed out?
Cheers again!!.
J
Cheers again!!.
J
https://citycarcup.co.uk/product/citycar-cup-exhaust-backbox/
If its good for racing it's good for street in take maybe a cold air or a better filter plus to make it worth the upgrade you might be better off with a ecu tune too
Sent from my G8341 using Tapatalk
check your insurance first , id not want to pay £££ to have a sports exhaust for a tiny increase in power
Hi thanks for your reply back! You mentioned Tune! On a 3 cylinder? What kind of power would the aygo give if fitted a filter, exhaust and then a tune? How much would a tune cost roughly.
Cheers.
J
17 hours ago, - A - Go - said:
Hi thanks for your reply back! You mentioned Tune! On a 3 cylinder? What kind of power would the aygo give if fitted a filter, exhaust and then a tune? How much would a tune cost roughly. Cheers.
J
Phantomtuning.co.uk on my old 16 aygo say
Stock 68 hp 95nm
Modified 72hp 100nm
For £325 but look around for prices intake and exhaust I'll be realistic and say 5-10%
Just don't expect something crazy like most people do oh put a intake on will give you 50hp
£4-600 for a remap so you will be in to £800-1000 10-15% gain, IMHO decent tyres, sort the suspension and brakes first - if you can brake harder and stay flatter in corners you will go faster
poly bushes will tighten up any car
If you was to go this route tts performance has a supercharger for £3350+vat
https://www.tts-performance.co.uk/single-post/2017/03/09/Toyota-Aygo
Depends on this plus other stuff they claim up to 120hp maybe 150ish nm
0-60 from 14 sec to 8 sec
🙄 £4-600 for a remap - no matter the power of a car if it doesn't handle or put the power down its pointless, i had my (Vauxhall)1.4 turbo remapped from 140 to 160 but i had it dialled back to 152 to make it more drivable
[emoji849] £4-600 for a remap - no matter the power of a car if it doesn't handle or put the power down its pointless, i had my (Vauxhall)1.4 turbo remapped from 140 to 160 but i had it dialled back to 152 to make it more drivable
Thanks all guys, ill look into this, sounds interesting!!
Cheers!!
J
