Hi all,
I own a 1997 carina e.
Recently the speedometer has become faulty. As soon as I start to drive forward or in reverse the speedometer goes upto about 40mph and stays on 40mph despite my real speed. When I stop driving the needle comes back down to zero.
Does the carina e have a cable rather than a speed sensor??
Is it likely a fault within the speedometer itself?
Any help would be appreciated
39 minutes ago, tmd12 said:
Hi all,
Just to add it's a manual gearbox and the 2.0 diesel engine if that makes any difference
  • 2 months later...
it has a speed gear which could have started to wear out .
you also have speed sensors on the wheel i believe
