Electric Windows Not Working
thimiostrikala
I have a problem with the windows when I turn off the car and take out the key I have a little time about 45 seconds to close the windows but if I open the door this time of 45 seconds is also lost when I take out the Battery I have to adjust the windows by closing a one the windows and holding the switch for a few seconds pulled to close and fight automatically you will wonder why I tell you this I tell you I do not want this process the windows continue to work automatically and let me remove the Battery of course it did not work so i think he lost his program please if anyone knows how to restore it to normal operation
I have a problem with the windows when I take out the key that I have about 45 seconds to close the windows if I open the door is lost
I have lm with the tarara I extract the key I have used 45 different to close the tadara I look door you lose
I have a problem with the windows when I take out the key that I have about 45 seconds to close the windows if I open the door, you lose
when I remove the Battery I have to adjust the windows by closing and holding the switch for a few seconds pulling to close automatically.
mine does not want these process windows to continue running automatically and let me remove the Battery
mine does not want a break the tarara to use to work and let me approach the market
