found a few older threads where the poster no longer comes here , id to find out more about the led mods for the window switches and the heater knob
if anyone has any info or saved pics id like to hear about it
asking about the heater knob not the console
i can see how to get a led inside the switch but would like some help on how its wired up internally
Not seen that mod, i take it's just for the pointer if so mount a led in the knob recess and either use a light pipe or pour it with clear resin
seen folk drill the dot and fit a wired 3mm led....nothing is said or shown where the wires run or how to prevent it tangling when you turn it
all dead pics /members have left
drill the dot, fill it with resin or use a bit of acrylic rod, mount the led on the console no wires to worry about then - tap the power from the console illumination
Edit. looking at the console again it looks like it has a light pipe behind the knob so it may not even need its own led
