Quarter Glass NSF
nigelglacey
Has anyone replaced a NSF quarter glass on a 2014 Yaris Hybrid?
Appreciate any assistance.
did it on a 2003. Easy job. New rubber seal and correct sealant. And very sharp knife. Cannot be very different..
Look on You Tube.
iirc the glass actually sits in the frame so the main window has to come out to remove the rail (screw at the top and 2 bolts) to remove the glass/large rubber
You shouldn't need it, a bit of lube may aid getting the rubber back in tho
Flash 22. Thanks for the help/ It was a relatively straightforward operation with the use of your diagram.
