Dash lights flashing
HeatherToyota
The dash lights on my Toyota Yaris 2011 wont stop flashing. I turned off the ignition and removed the key but the dash lights keep flashing. Has anyone had experience of this? What should I do?
I guessing this is the 1.33L engine?
If so then the problem is caused by a known fault relating to a small module (located under the bonnet) called the ECO run module (or convertor). As far as I know replacement is the only option. Its an easy fix... not sure about the cost although around £150 ish rings a bell.
1.33 Engine?
As above see:
Try and avoid a used one as its likely to be faulty or fail. Latest part from Toyota has been modified and needs a couple of extra bits to fit:
Order
1 x G92C0-52050 ECO RUN CONVERTER £112.95 + VAT
1 x 90159-50385 BOLT £0.90p + VAT
1 x F1334-52020 BRACKET £11.52 +VAT
  • 8 months later...
I can confirm I had the same problem as described above.  I have also successfully replaced the ECU run converter as per the model number described.  I also bought a bracket, but managed to simply used the existing one, so will be returning that.
Yes it happened on the wife's 2011 Yaris, it's a plug and play item and it cost me £110 and it takes all of 5mins to fit
