Oil stop leak additive has changed the ICE work , the car feels new again !
TonyHSD
Hi everyone,
I had recently a positive experience using a oil additive that has made my car feels new again. I have an oil leak, not bad one for now but it’s there since 2.5 years and 100k miles. Since it’s not too bad and the car only needs 500ml of oil top up between change (every 10k miles) I do use sometimes an oil stop leaks from various producers with no success. 1000 miles ago I decided to use this: https://www.amazon.co.uk/Wynns-1831027-77441-Engine-Stop/dp/B001NUOJYY/ref=sxts_sxwds-bia-wc-drs-ajax1_0?crid=25Q94DDGEQI1B&cv_ct_cx=wynns+oil+stop+leak&dchild=1&keywords=wynns+oil+stop+leak&pd_rd_i=B001NUOJYY&pd_rd_r=8fbbd609-bd88-4d70-b591-95422b4548df&pd_rd_w=V0gO5&pd_rd_wg=PjnDE&pf_rd_p=db5ec505-5260-4be8-b12d-cc6f13505a81&pf_rd_r=EG7CC8SVGYWS4S2GFXND&psc=1&qid=1602768401&sprefix=Wynns+oil+%2Caps%2C230&sr=1-1-e00012f1-1c8d-4cb3-8ce3-384c62c0be4f
lol, I poured in and drove the car as usual,. What a difference, the engine became very quiet and more responsive, it’s like you switch to power mode but with the smoothness of an eco mode. The car feels much better, even better than when changing the oil. Would this additive help stop the oil leak, well probably not as I did try theirs non pro can in the past without success., however what this additive does is to rejuvenate all rubber and silicone seals including valve stems, and obviously there are some friction modifiers in that help reduce internal friction and very likely wear of the engine. I can’t recommend enough this oil stop leak for all Toyota hybrids owners with cars 5 years and older. The difference in feel and performance is astonishing. Bought one for my other half even though she has no any oil leaks at all. This thing is very liquidy, and does not change the viscosity of the oil, something very important for the hybrid engine.
Remember you do so at your own risk, I do not accept any liability for damage in your vehicle as a result of using any additives even I recommend them. , I am pretty sure you will not regret using this one. I will definitely use again., or look for something similar like that through half oil change intervals 5k miles. https://www.amazon.co.uk/Wynns-1831062-47041-Friction-Proofing/dp/B001NURVDA/ref=sr_1_2?crid=U1MCQXAMX6PK&dchild=1&keywords=wynns+friction+proofing&qid=1602769395&sprefix=wynns+fr%2Cautomotive%2C197&sr=8-2
It has to be good, it's the "Professional Formula".:toast:
I wonder what the Amateur Formula is like?
Exactly same I believe, but the price difference is small so let be a Pro’s 😂, no joke this make the car really nicer  to drive , the transition between ev and hybrid is less noticeable, it’s like a full ev now, so smooth and more responsive. Just give it a try.👍
I`ve used this same stuff in my bike, a oil cooled suzuki bandit 1200. It had a developed a drip from one of the oil lines from the sump to the oil cooler after using fully synthetic oil. The wynns worked a treat.
